[Proj] Cosmetic latitudes, and the diacritics of Josef Krovak and others
Mikael Rittri
Mikael.Rittri at carmenta.com
Fri Mar 20 02:34:00 PDT 2009
Hello,
I lump together some unrelated light-weight questions here:
A) For some projections, a parameter for central latitude can be given,
but it does not really affect the shape of the map - it just creates
an extra offset in the northing values (in addition to the offset
due to the FalseNorthing).
My question: is there an established terminology for such
a central latitude?
When documenting projections, I would like to write something
like "the central latitude can be specified but is just cosmetic",
with a link to a glossary entry for "cosmetic central latitude".
But is "cosmetic" the best word?
B) What are the correct diacritical marks for Krovak? (As in Josef
Krovak,
inventor of the Krovak projection for Czechoslovakia.)
Clifford Mugnier gave two diacritial alternatives for "Krovak" in his
Czech
column ( http://www.asprs.org/resources/grids/01-2000-czech.pdf ):
1) a slash through the "o" as in the Danish letter (or a lower-case
symbol for the empty set), and an acute accent on the "a".
2) a hacek (small v) above the "r", no slash through the "o", but
His third alternative is to omit the diacritical marks, which most
people on the Internet seem to do. Of course, when "Krovak" is the
name of a projection, it seems best to omit them. But Mugnier's text
implies that alternative 1) is the correct version for Josef Krovak
himself, which puzzled me since there is no slashed o in the Czech
or Slovak alphabets (according to http://www.omniglot.com/writing ).
So, does anyone know a definitive answer? (Otherwise, how much
would omitted diacritics have offended Josef Krovak?)
C) Is it correct that "Bursa-Wolf" should have a hacek on the "s",
and no "e" in "Wolf"?
Best regards,
Mikael Rittri
Carmenta AB
SWEDEN
www.carmenta.com
More information about the Proj
