[Proj] cs2cs
Ames, Kieran J. Kieran.Ames at us.ngrid.com
Fri Mar 20 11:46:13 PDT 2009
Can I please ask the list for some guidance?
In an attempt to convert some data from projected to lat/lon, I'm
attempting to use cs2cs.
The data:
My coordinates of 2174727 164482 are based on NAD27 3104 (Long Island).
My lat/lon of -73.370096 40.675382 is based on a geocoding calculation
from a Sagent geocoding engine.
I'm attempting to use cs2cs to calculate lat/lon values for a rather
large file.
In testing, I use the command:
echo 2174727 164482 nad27:3104  |c:\ms4w\proj\bin\cs2cs    -E  -f %3.6f
+init=nad27:3104  +to +proj=latlong +datum=NAD83
This returns coordinates of -55.478096 40.211109... somewhere out in the
Atlantic Ocean.
I've tried a brute force approach against all the NAD27, NAD83 and EPSG
definitions but cannot come up with anything close to the lat/lon I
expect.
I've been told that the coordinates I'm using are actual and not
"padded" for any reason.
If anyone has any insight as to how I could resolve this issue, I'd be
most appreciative.
Thank you
Kieran Ames
This e-mail and any files transmitted with it, are confidential to National Grid and are intended solely for the use of the individual or entity to whom they are addressed.  If you have received this e-mail in error, please reply to this message and let the sender know.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20090320/527d94bc/attachment.html>
