[Proj] Error during the coordinate transformation‏
Tue Mar 31 14:21:11 PDT 2009
Fernando Javier Luyo Zegarra wrote:
> Hello,
> I'm developed a routine for transforming coordinates of points which are
> in PSAD56 Zone 18S (srid = 24878) to Wgs84 Zone 18s (srid = 32718)
> The items are stored in the fields "geom" the table "MyTable" (srid =
> 24878).
> To perform the operation using the following syntax:
>        select Transform (geom, 32718) from MyTable
> Reviewing the results found that there is an error:
> Example:
> Point in Psad56 Zn 18s
>         X = 264365.2955 Y = 8665287.3660 Z = 0.0000
> The result of the transformation is:
>         X = 264366.1196 Y = 8665292.17 Z = 0.0000
> However, the same point in cartografia WGS84 Zone 18S has the following
> coordinates:
>         X = 264143.0640 Y = 8664919.0231 Z = 0.0000
> Apparently the SRID of the parameters are not properly used or applied
> incorrectly the function Transform ()
Fernando,
I would encourage you to determine what PROJ.4 init strings are associated
with 32718 and 24878.  It looks like there is a missing or incorrect datum
shift being applied.
Best regards,
