[Proj] libproject benchmark
Gerald I. Evenden geraldi.evenden at gmail.com
Fri May 1 13:59:13 PDT 2009
Glory be and many thanks to libtool, libproject, once known as libproj4 has
just seen the light of day as a shared library. The once static linked
mapmaking routines linked in to the library and reduced their disk footprint
from about 750k down to around 20k.
Still a bit of a problem resolving details on the *config.h in spotting
references to the pthread and gsl libraries.  The proj-4.* stuff has never
seemed to ever attemp to provide thread proof service nor employ gsl.  The
latter should, of course, be optional because of licensing but I can't see
any reason not thread-proofing.  But proj-4.* is years out of date so the
comparison is specious.
Hopefully not too many more days until release of libproject.
The whole religious complexion of the modern world is due
to the absence from Jerusalem of a lunatic asylum.
-- Havelock Ellis (1859-1939) British psychologist
