[Proj] Question on colon DMS format
Hamish
hamish_b at yahoo.com
Mon May 18 04:52:31 PDT 2009
> Hamish wrote:
> > GRASS still uses this format, the following are allowed:
> > DDDh
> > (DDD.DDDDDDh is not allowed, as E has problems with
> > mistranslation into e.g. e+06; so +/- DDD.DDDDD must be
> > used there; could probably be coded around but currently isn't)
Gerald wrote:
> I do not understand the "h".
(I just meant hemisphere)
> Problems with a NEWS suffix sign sounds like a library problem.
> A proper lexical analyser should sense existance of an e|E
> followed by a signed number.
or just my bad memory, or assumption about why something so simple wasn't
implemented (I'm too trusting there was a good reason). all I'm really
sure of is that at present you can't mix degree-only with decimal places
and NSEW in GRASS. Maybe it is a simple libgrass coding fix to enable
it after all. shrug, not relevant for this thread.
> The "D" of FORTRAN infamy is not recognized.
but "U" and "f" maybe?
> In any case proj_dms2rad and preceeding versions have not put a
> restriction on ddd.dddd.
ok, good.
> > GRASS enforces %02d for MM and SS input, but I don't think
> > that's necessary and have considered removing it.
> Don't use %2d as that will cause space for numbers under
> 10.
%02d pads the space with a zero. my point was that GRASS expects to
see 123:45E or 123:05E, but 123:5E is considered an error.
> "%d" will work OK with proj_dms2rad.
ok, good.
> Basic, old time, standard ASCII does *not* have a degree
> mark and that is why I have not used it.
you mean in the days before they discovered the number 129? ;-)
Hamish
More information about the Proj
