[Proj] Coordinate change transforming to EPSG:4326
Miguel R. Luaces miguelrluaces at gmail.com
Tue May 26 09:03:03 PDT 2009
Dear all,
I am using proj.4 as part of PostGIS. Version 1.3.1 of postgis included PRO
Rel. 4.5.0, whereas version 1.36 includes PROJ Rel. 4.6.1
When I transform a coordinate from EPSG:23209 to EPSG:4326 I get the
following results.
In Postgis 1.3.1 (PROJ.4 Rel. 4.5.0):
"POINT(549556.009066526 4801796.3531214)";"POINT(-8.38839299999999
43.3657910268222)"
In Postgis 1.3.6 (PROJ Rel. 4.6.1):
43.3666118995462)"
The second coordinate of the transformation to 4326 changes by 0.004 degrees
(approx).
If I use cs2cs from command line (version proj446_win32), I get:
-8.38839300     43.36661190
Why do I get a different result in postgis 1.3.1 and in postgis 1.3.6?
Why do I get the same result in PROJ4 4.4.6?
I do not understand. I hope anybody can help me.
Best regards,
  Miguel
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20090526/841cb6e6/attachment.html>
