[Proj] ESRI:102026 with +lat_0=0 +lon_0=0: bug or feature?
Ivan Boldyrev
lispnik at gmail.com
Thu Nov 12 22:35:53 PST 2009
Greetings!
spatialreference.org states that central meridian of this projection is 95:
PARAMETER["Central_Meridian",95],
(See http://spatialreference.org/ref/esri/102026/)
Howerver, in esri file bundled with proj4 its parameters are:
+proj=eqdc +lat_0=0 +lon_0=0 +lat_1=15 +lat_2=65 +x_0=0 +y_0=0
+ellps=WGS84 +datum=WGS84 +units=m no_defs
+lon_0 should be 95, not 0, shouldn't it?
Ivan Boldyrev
More information about the Proj
