[Proj] Mémoire sur la représentation des surfaces et les projections des cartes (Auguste Tissot, 1881)
    Paul B. Anderson
    pbander at cavtel.net
    Sun Nov 15 10:22:38 PST 2009
- Charles,
Thanks for the Google books trick! I'll use it from now on.
One of the books in my personal library is:
J. H. Lambert's 'Notes and Comments on the Composition of Terrestrial and
Celestial Maps',
Translated and Introduced by Waldo R. Tobler, 1972
Published by the University of Michigan,
Department of Geography
Ann Arbor, Michigan 48104
Dr. Tobler gave me the copy I have, and I have no idea where one could find
another.
- Paul
----- Original Message -----
To: "PROJ.4 and general Projections Discussions" <proj at lists.maptools.org>
Sent: Sunday, November 15, 2009 12:23 PM
Subject: RE: [Proj] Mémoire sur la représentation des surfaces et les
Thanks for the pointer.  Indeed Google Books is a treasure trove for old
books.  One other oldie is
    Johann Heinrich Lambert 1772
    Beyträge zum Gebrauche der Mathematik und deren Anwendung,
    http://books.google.com/books?id=sf82AAAAMAAJ
This is only part 3; I couldn't find the other parts on Google.
I have found 2 problems with Google Books
(1) The indexing of books is rather hit-or-miss.  This is particularly a
problem when searching for journal articles (some journals appear with
variant of the title, the volume number isn't listed in the search
results, etc.).
(2) The scanning is sometimes hit-or-miss.  Some pages are accidentally
skipped.  Fold-out pages of figures are not folded out.  Etc.
For this reason, it would be great if someone could start compiling a
bibliography of online books and papers on projections.  I started such
a bibliography for geodesics at
    http://trac.osgeo.org/proj/wiki/GeodesicCalculations#TheHistory
(which now has 75 entries) and several of the works I include (by Gauss,
Helmert, etc.) deal with projections.
BTW, the URL for Tissot's book can be shortened to
    http://books.google.com/books?id=a5YOAAAAYAAJ
  --Charles
Charles Karney <ckarney at sarnoff.com>
Sarnoff Corporation, Princeton, NJ 08543-5300
Tel: +1 609 734 2312
Fax: +1 609 734 2662
________________________________________
From: proj-bounces at lists.maptools.org [proj-bounces at lists.maptools.org] On
Behalf Of Paul B. Anderson [pbander at cavtel.net]
Sent: Sunday, November 15, 2009 10:04
To: PROJ.4 and general Projections Discussions
Subject: [Proj] Mémoire sur la représentation des surfaces et les
- Hi everyone,
If there is any interest here, Google has scanned the French text:
By Auguste Tissot (1881)
http://books.google.com/books?id=a5YOAAAAYAAJ&printsec=frontcover&dq=Auguste+tissot&ei=LAoAS-_lFaD2ygT9vOz3Dg#v=onepage&q=&f=false
Note that in Google's PDF download version there are about 7 blank pages
between the book cover and where the text begins.
Take care,
- Paul
More information about the Proj
