[Proj] Mémoire sur la représentation des surfaces et les projections des cartes (Auguste Tissot, 1881)
Michael P Finn
mfinn at usgs.gov
Wed Nov 18 06:58:42 PST 2009
Charles,
We will capture any pertinent URL, for example on-line books. Where
possible (on the newer references) we will have the DOI number. References
we get through the USGS Library, for example PDFs of an article, can not
be stored indefinitely and we cannot re-serve them. So, in these cases, we
likely will have a link to the journal's website.
Lisa, would you send Charles a small sample of a few entries?
Here is the site: http://wikindx.sourceforge.net/. It looks like I may
have caused come of your confusion because the software we are using is
not spelled with an "e" in it.
Mike
"Karney, Charles" <ckarney at Sarnoff.com>
To:
PROJ.4 and general Projections Discussions <proj at lists.maptools.org>
Cc:
"dstrebe at mapthematics.com" <dstrebe at mapthematics.com>,
"pbander at cavtel.net" <pbander at cavtel.net>, "E. Lynn Usery"
<usery at usgs.gov>, Elisa C Wood <ecwood at usgs.gov>
Date:
11/17/2009 07:17 AM
Subject:
Re: [Proj] Mémoire sur la représentation des surfaces et les projections
Sent by:
proj-bounces at lists.maptools.org
Michael,
Thanks for the update:
A couple of questions:
(1) Can you provide a pointer for WIKINDEX? Google turns up a lot of
hits (with and without a repeated "I"). I'm not clear which is the one
you're referring to.
(2) Besides having the text of the bibliography online, in what other
ways will it be an online resource? Possibilities are:
* Link to Google Books, adsabs.harvard.edu, gallica.bnf.fr,
math.dartmouth.edu/~euler, www.archive.org, UMich, and other online
repositories (with page number embedded in the link if appropriate)
* DOI link
* Worldcat/OCLC link
* Links to translations, reviews, corrections, scans of missing pages,
etc.
Do you have a sample entry?
Regards,
Charles
Charles Karney <ckarney at sarnoff.com>
Sarnoff Corporation, Princeton, NJ 08543-5300
Tel: +1 609 734 2312
Fax: +1 609 734 2662
________________________________________
From: proj-bounces at lists.maptools.org [proj-bounces at lists.maptools.org] On
Behalf Of Michael P Finn [mfinn at usgs.gov]
Sent: Monday, November 16, 2009 19:40
To: PROJ.4 and general Projections Discussions
Cc: dstrebe at mapthematics.com; pbander at cavtel.net; E. Lynn Usery; Elisa C
Wood
Subject: Re: [Proj] Mémoire sur la représentation des surfaces et les
I should have said we. I, along with daan Strebe, Lynn Usery, and Lisa
Wood, with some assistance from Paul Anderson, are contributing a project
of the International Cartographic Association Commission on Map
Projections for an on-line bibliography of map projections. We have
completed initial input (~ 3,000 listings) of all of John Snyder?s
Bibliography of Map Projections [Snyder, J.P., and Steward, H. (1988):
Bibliography of map projections. US Geological Survey Bulletin 1856.
Washington D.C., U.S. Government Printing Office (updated in 1994)] into
an EndNote file.
EndNote is a bibliographic management software tool that is commercially
licensed. We also have all entries from the earlier WIKINDEX attempt that
was hosted on Mapthematics.com. WIKINDEX is an open source software
application for the same purpose as EndNote. We are quality controlling
the entries at this point. Next we will export them from EndNote and
import them into the latest version of WIKINDEX.
We can either host the bibliography in WIKINDEX on our current test space
or re-host it on Mapthematics.com. The access to the bibliography will be
read only. The Chairman of the Commission (currently daan) will provide
write access to those wishing to update the file. We plan to write an
article for submission to Cartography and Geographic Information Science
detailing the history, accomplishments, and future of this project. Lynn
is currently briefing this information to the International Cartographic
Conference in Santiago, Chile this week.
Let me know if I can answer any questions.
Mike Finn
Michael P. Finn
Research Cartographer
Center of Excellence for Geospatial Information Science
U. S. Geological Survey
Denver Federal Center
Box 25046, Mail Stop 510
Denver, CO 80225
(303) 202-4544
mfinn at usgs.gov
http://cegis.usgs.gov<http://cegis.usgs.gov/>
FedEx/ UPS/ DHL:
Building 810, Mail Stop 510
6th Avenue and Kipling Street
Denver, CO 80225
To: "PROJ.4 and general Projections Discussions"
Date: 11/16/2009 03:04 PM
Sent by: proj-bounces at lists.maptools.org
I am working on this as a part of an ica project
I will send more info when I don't have to type on a crackberry
Mike
----- Original Message -----
Sent: 11/16/2009 01:28 PM CET
To: "PROJ.4 and general Projections Discussions" <proj at lists.maptools.org>
Karney, Charles wrote:
> For this reason, it would be great if someone could start compiling a
> bibliography of online books and papers on projections. I started such
> a bibliography for geodesics at
> http://trac.osgeo.org/proj/wiki/GeodesicCalculations#TheHistory
> (which now has 75 entries) and several of the works I include (by Gauss,
> Helmert, etc.) deal with projections.
Thanks Charles, very useful. Also interesting would be:
M. Pommiés: Manuel de l'ingénieur du cadastre. Paris 1804
http://books.google.nl/books?id=CTIVAAAAQAAJ&pg=RA3-PA30&source=gbs_selected_pages&cad=0_1#PPP1,M1
the official manual for the Napoleonic cadastre. More practical than
most of the works you mention, but very important, as it forms the base
for most cadastral surveys in continental Western Europe in the first
half of the 19th century.
Jan
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
Proj mailing list
Proj mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20091118/acabee4c/attachment.html>
More information about the Proj
