[Proj] ToWGS84 for Germany, NRW?
Milo van der Linden
milovanderlinden at gmail.com
Thu Oct 15 06:56:41 PDT 2009
Byte,
Do you have the proj string or the EPSG code for the projection you use
natively in Germany? I think it is needed to see what ellipsoid/spheroid
is native to you to determine the +towgs84 transformation.
Bytechanger schreef:
> Hi,
> I want to convert 4326 to 31466....
> But there is a difference of 50m !!
> I think I need right +towgs84 for Germany , NRW, Rhein-Erft-Kreis ??
> Greetings
> Byte
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
