[Proj] lcc tangent latitude
buddy bajorin buddy.bajorin at rock.com
Thu Oct 15 07:37:34 PDT 2009
Greetings =)
Could someone please help with projection issues?
In trying to convert a raster image (gif) into a geotiff so that it can
be reprojected into mercator. I'm very new at this so have attempted to
read the docs carefully, but i have clearly made a mistake.
Since i'm new, and am using a linux box I have found that gdal seems to
be the way to go, unless someone has a better suggestion (need command
line for automation).
The projection information for the gif image is that it is a lambert
conformal conic, but specifies a tangent latitude, instead of the normal
1 or two latitudes of natural origin. Here is the info and source
information:
########## SOURCE PROJECTION INFORMATION ###################
## REF http://www.nws.noaa.gov/noaaport/html/icdtb48e.html #
Eastern CONUS Lambert
Satellite: GOES East
Projection: Lambert Conformal
Tangent Latitude: 25.000N
Reference Longitude: 95.000W
Reference Grid: AWIPS Grid 211*
* The Dx, Dy grid increment (at 25 deg north) w as selected
so that the grid spacing would be exactly 80.0 00 k m at
35 deg north
Lower Left: 16.369N 113.133W
Lower Right: 14.335N 65.091W
Upper Right: 57.289N 49.385W
Upper Left: 59.844N 123.044W
1.0159Km @ 25.000N Visible
5120x5120
so not knowing what I am doing, and googling for all that i can find I
came up with the following means to set the projection, and reproject.
gdal_translate -of gtiff -a_srs '+proj=lcc +lat_ts=25 \
+lon_0=-95 +x_0=0 +y_0=0 +datum=WGS84 +units=m +no_defs' \
-a_ullr -123.044 59.844 -65.091 14.335 test.gif test.tif
I'm guessing the 'lat_ts' parameter is incorrect, i just happened to see
it somewhere, but i have also tried setting the two lat parameters to 25
as well, which did not work. I also tried using default lcc projection
information from ArcView for that projection to no avail.
Once finished my settings so far to convert to mercator are as follows
gdalwarp -t_srs '+proj=merc +a=6378137 \
 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 \
 +units=m +nadgrids=@null +no_defs' test.tif mercator.tif
I would really appreciate any help anyone can offer.. i've been banging
my head off the wall trying to figure this out, it has sort of become a
quest now... the issue seems to be using a tangent latitude instead of
the 1 or 2 latitudes of origin.
thanks much,
--buddy
You Rock! Your E-Mail Should Too! Signup Now at Rock.com and get 250MB of Storage!
http://webmail.rock.com/signup/
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20091015/4e6d8707/attachment.html>
