[Proj] Working with NZGD2000 and NZTM2000
Hamish hamish_b at yahoo.com
Thu Sep 10 12:32:13 PDT 2009
Mohammad Raza wrote:
> I am trying to get my copy of Proj4 prepped up for NZGD2000
> and NZTM2000.
> Does Proj4(.6.1) support NZGD2000 and NZTM2000? If not,
> what do I need to do to add support for these datums?
NZGD2000 is essentially WGS84 with the GRS80 ellipsoid.
"+ellps=grs80 +towgs84=0,0,0" is enough for most purposes.
There is no such thing as NZTM2000 datum. The NZ trans. merc.
projection is defined as using the NZGD2000 datum.
see EPSG 2192,
http://www.linz.govt.nz/geodetic/datums-projections-heights/geodetic-datums/new-zealand-geodetic-datum-2000/
and Cliff's Grids and Datums column in PE&RS,
http://www.asprs.org/resources/grids/
NZGD 2000 supersedes NZGD 1949.
Hamish
