[Proj] armenian coordinate system
Markus Neteler
neteler at osgeo.org
Sat Apr 3 07:31:50 PDT 2010
On Sat, Apr 3, 2010 at 3:23 PM, Greg Troxel <gdt at ir.bbn.com> wrote:
> Jean-Claude REPETTO <jrepetto at free.fr> writes:
>> Greg Troxel a écrit :
>>> # Pulkovo 1942 / 3-degree Gauss-Kruger zone 38
>>> <2555> +proj=tmerc +lat_0=0 +lon_0=114 +k=1 +x_0=38500000 +y_0=0 +ellps=krass +units=m +no_defs <>
>> This definition is incomplete : the datum shift is missing. Yous should
>> add the +towgs84 parameters.
> That's straight out of the epsg file, so perhaps a bug to EPSG is in order.
Note: The nad/epsg file does not contain datum values when several datums exist.
I tried to check in http://www.epsg-registry.org/ but it is
non-functional right now.
But I could generate it with a GDAL tool:
epsg_tr.py -pretty_wkt 2555
PROJCS["Pulkovo 1942 / 3-degree Gauss-Kruger zone 38",
GEOGCS["Pulkovo 1942",
DATUM["Pulkovo_1942",
SPHEROID["Krassowsky 1940",6378245,298.3,
AUTHORITY["EPSG","7024"]],
TOWGS84[23.9,-141.3,-80.9,-0,0.37,0.85,-0.12],
AUTHORITY["EPSG","6284"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.01745329251994328,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4284"]],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",114],
PARAMETER["scale_factor",1],
PARAMETER["false_easting",38500000],
PARAMETER["false_northing",0],
AUTHORITY["EPSG","2555"],
AXIS["X",NORTH],
AXIS["Y",EAST]]
@Beppe: can you try this?
Hope this helps,
Markus
http://gis.fem-environment.eu/
More information about the Proj
