[Proj] cs2cs's +towgs84 usage
Ilumas muginaa at gmail.com
Wed Apr 21 08:56:58 PDT 2010
Dear list,
could you kindly confirm that the cs2cs's +towgs84 parameters remain the
same for a certain datum regardless of the direction of the transformation.
Some people (e.g.
http://n2.nabble.com/Datum-Shift-WGS84-to-Arc1960-not-working-propberly-td3410479.html)
<http://n2.nabble.com/Datum-Shift-WGS84-to-Arc1960-not-working-propberly-td3410479.html>seem
to suggest that the values need to be negated when going FROM wgs84 TO
something else, but this seems a bit strange to me. Unfortunately all the
examples in the man pages seem to be about changing the coordinates TO
wgs84...
Thanks a lot in advance!
ilumas
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20100421/ec079039/attachment.html>
