[Proj] quoting +nadgrids ?
Frank Warmerdam
warmerdam at pobox.com
Sun Aug 1 09:03:44 PDT 2010
Glynn Clements wrote:
> Personally, I'm not inclined to suggest that PROJ should be
> introducing this sort of workaround for issues with software which
> uses it.
> However, if you decide to go that route, URL encoding (%##, e.g. %20
> for space) serves roughly this purpose (although the use of '+' for
> space wouldn't be desirable here). This assumes that % is uncommon in
> PROJ parameter values.
Glynn,
I had been avoiding "normal" escaping schemes primarily to avoid
the escaping getting interpreted earlier in the processing chain,
though I suppose url encoding would not be widely used. Also, to
the best of my knowledge the only things we might need to escape
would be " " and "+".
> Another option would be to provide utility functions to convert
> between an argument list (i.e. a list of strings) and a string. This
> would make it easier for GDAL (etc) to "do it right".
In fact GDAL uses pj_init_plus() which takes the whole string rather
than a set of pre-separated options. So PROJ.4 already does have
a natural place to put the parsing rules for applications that use it.
Earlier I suggested this issue wasn't really a PROJ.4 issue, but now
that I think about pj_init_plus() it clearly is a PROJ.4 issue. Based
on that it seems to come down to how to do the escaping for interpretation
by pj_init_plus().
I had proposed the @@@space@@@ idea just because it wouldn't be interpreted
anywhere else, though it is somewhat peculiar. Can you, or anyone,
provide an argument for a different approach? Were you suggesting url
encoding because it was easily extended to other escaping operations?
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
More information about the Proj
