[Proj] Portuguese Modified Grid - Datum 73
Roger Oberholtzer
roger at opq.se
Wed Feb 17 01:27:16 PST 2010
On Tue, 2010-02-16 at 17:34 +0000, Jose Gonçalves wrote:
> Hello
> The proj string you refer is not correct. What is called in the EPSG
> database "Portuguese Modified Grid - Datum 73" (epsg code 27492) is
> the projection used in Portugal for the local datum called Datum 73.
> Datum 73 was established in 1973 and is based on the Hayford
> ellipsoid.
> The correct definition of the projection can be found in the epsg file
> distributed with proj:
I am confused about the lat_0 term. All references for this say that
this is 39º 40’ 00’’ N. Also, in the files I have with proj, it is
defined as:
<27492> +proj=tmerc +lat_0=39.66666666666666 +lon_0=-8.131906111111112
+k=1.000000 +x_0=180.598 +y_0=-86.98999999999999 +ellps=intl +units=m
+no_defs no_defs <>
Is it standard to use 39º 00’ 00’’ N instead? The people I am doing this
for have referenced
http://www.igeo.pt/produtos/Geodesia/inf_tecnica/sistemas_referencia/Datum_73.htm
(Note: the reason I missed this entry in proj at the start and asked the
original question was that I looked for "Portugal" in the file. I never
thought to look for "Portuguese".)
> # Datum 73 / Modified Portuguese Grid (deprecated)
> <27492> +proj=tmerc +lat_0=39d00' +lon_0=-8.131906111111112 +k=1
> +x_0=180.598 +y_0=-86.98999999999999 +ellps=intl +units=m +no_defs <>
> It is a Transverse Mercator projection with central point:
> lat_0=39d00'00.000"N
> lon_0= 8d07'54.862"W
> No scale factor in central meridian is applied (+k_0=1)
> It has a small false easting/northing
> x_0=180.598
> y_0=-86.990
Roger Oberholtzer
OPQ Systems / Ramböll RST
Ramböll Sverige AB
Krukmakargatan 21
P.O. Box 17009
SE-104 62 Stockholm, Sweden
Office: Int +46 10-615 60 20
Mobile: Int +46 70-815 1696
More information about the Proj
