[Proj] Welcome to the "Proj" mailing list
Jan Hartmann j.l.h.hartmann at uva.nl
Mon Jan 4 03:38:41 PST 2010
I would prefer to keep the code of the library itself as standard-C like
as possible. It is scientific programming, could be done just as well in
Fortran (preferably not, of course :-)). On the other hand, what someone
does on top of this library (e.g. building user interfaces in Fortran),
should be doable in any other language.
Jan
On 4-1-2010 12:27, jamesmikedupont at googlemail.com wrote:
> Yes,
> Of course. My plan was to test this and submit it to the main branch.
> In fact, I would not have published this at all, but was having
> problems and wanted help. Now I have resolved the issues and this
> branch is not needed any more.
> This is just a working snapshot.
> Ideally there more work to do with c++ and proj.
> Like to move the configuration of the projections to templates..
> mike
> On Mon, Jan 4, 2010 at 12:20 PM, Jan Hartmann<j.l.h.hartmann at uva.nl>  wrote:
>> If it is just a patch to make the source code c++ compliant, IMHO it belongs
>> in the main branch. Useful for indepentdent C++ projects that would like to
>> link in the PROJ4 library.
>> Jan
>> On 4-1-2010 12:10, jamesmikedupont at googlemail.com wrote:
>>> It does not do anything more at the moment.
>>> This is just compiling with c++, you can apply the patch if you like.
>>> mike
>>> On Mon, Jan 4, 2010 at 12:09 PM, Jan Hartmann<j.l.h.hartmann at uva.nl>
>>>   wrote:
>>>> On 4-1-2010 8:47, jamesmikedupont at googlemail.com wrote:
>>>>> In addition, I have started a c++ branch of proj4, and have resolved
>>>>> some compile problems.
>>>>> Feel free to check it out
>>>>> http://github.com/h4ck3rm1k3/ProjC--/
>>>>> mike
>>>> Just curious, what does this branch do that the main tree doesn' t?
>>>> Jan
