[Proj] Projections with respect to India
Anisha Kaul
anisha.kaul at hitechroboticsystemz.com
Sat Jan 9 04:29:01 PST 2010
Hello to all,
I downloaded an OSM map file namely "india.osm.bz2".
I transported it in PostgreSQL database "gis" with the command :
./osm2pgsql -m -d gis india.osm.bz2
The above command resulted in the creation of the following tables filled with data in database "gis"
gis=# \d
List of relations
Schema | Name | Type | Owner
public | geometry_columns | table | anisha
public | planet_osm_line | table | anisha
public | planet_osm_point | table | anisha
public | planet_osm_polygon | table | anisha
public | planet_osm_roads | table | anisha
public | polygon_oid_seq | sequence | postgres
public | spatial_ref_sys | table | anisha
Now to convert the map data of one of the above tables in a shape file, I issued the following command:
pgsql2shp -f myfile gis planet_osm_line
The projection file now generated namely "myfile.prj" contains the following !
PROJCS["WGS84 / Simple Mercator",GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS_1984", 6378137.0,
298.257223563]],PRIMEM["Greenwich", 0.0],UNIT["degree", 0.017453292519943295],AXIS["Longitude",
EAST],AXIS["Latitude", NORTH]],PROJECTION["Mercator_1SP_Google"],PARAMETER["latitude_of_origin",
0.0],PARAMETER["central_meridian", 0.0],PARAMETER["scale_factor", 1.0],PARAMETER["false_easting",
0.0],PARAMETER["false_northing", 0.0],UNIT["m", 1.0],AXIS["x", EAST],AXIS["y", NORTH],AUTHORITY["EPSG","900913"]]
I am confused with the resultant projection file,
Now how should I specify the projection values/SRS with respect to India ?
I tried to write projection as follows in a python file with respect to the above generated projection file:
+proj=merc +lon_0=0.0 +k=1.0 +x_0=0.0 +y_0=0.0 +ellps=WGS84 +datum=WGS84 +units=m +no_defs
But still not maps were generated !!
Kindly guide where I am wrong ???
Thanking you in anticipation,
Regards,
Anisha Kaul
Hi-Tech Gears Limited, Gurgaon, India
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20100109/f6f55803/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20100109/f6f55803/attachment.obj>
More information about the Proj
