[Proj] Projections with respect to India
Greg Troxel
gdt at ir.bbn.com
Sat Jan 9 07:06:19 PST 2010
I downloaded an OSM map file namely "india.osm.bz2".
I transported it in PostgreSQL database "gis" with the command :
./osm2pgsql -m -d gis india.osm.bz2
pgsql2shp -f myfile gis planet_osm_line
The projection file now generated namely "myfile.prj" contains the following !
PROJCS["WGS84 / Simple Mercator",GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS_1984", 6378137.0,
298.257223563]],PRIMEM["Greenwich", 0.0],UNIT["degree", 0.017453292519943295],AXIS["Longitude",
EAST],AXIS["Latitude", NORTH]],PROJECTION["Mercator_1SP_Google"],PARAMETER["latitude_of_origin",
0.0],PARAMETER["central_meridian", 0.0],PARAMETER["scale_factor", 1.0],PARAMETER["false_easting",
0.0],PARAMETER["false_northing", 0.0],UNIT["m", 1.0],AXIS["x", EAST],AXIS["y", NORTH],AUTHORITY["EPSG","900913"]]
This is really an OSM question more than a proj question.
OSM stores data in WGS84 EPGS4326 (in the xml file). But, osm2pgsql by
default converts to Google Spherical Mercator EPGS:900913. If you are
trying to use this data in a local coordinate system (an Indian TM or
lambert conformal conic system?), then you are probably better off
importing in EPSG4326.
http://wiki.openstreetmap.org/wiki/Osm2pgsql
http://wiki.openstreetmap.org/wiki/Mapnik#osm2pgsql
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20100109/ffd1416a/attachment.sig>
More information about the Proj
