[Proj] Belge 1972 / Belgian Lambert 72 (31370) - towgs84 parameters
Jan Hartmann j.l.h.hartmann at uva.nl
Wed Jan 20 02:28:50 PST 2010
Hi Thibaut,
the most recent version of the EPSG database, 7.4, (www.epsg.org) has
two definitions for the datum shift from Belge Lambert to WGS84 (they
call it a coordinate transformation). I'l give the parameters as a PROJ
string, with rotations converted from radians to degrees and sign-converted
nr 162 and 164 (accurate to a meter) :  +proj=lcc
+lat_1=51.16666723333333 +lat_2=49.8333339 +lat_0=90
+lon_0=4.367486666666666 +x_0=150000.013 +y_0=5400088.438 +ellps=intl
+towgs84=-99.059,53.322,-112.486,0.419,-0.830,1.885,-1 +units=m +no_defs
nr 163 and 166: (accurate to 20 cm): +proj=lcc +lat_1=51.16666723333333
+lat_2=49.8333339 +lat_0=90 +lon_0=4.367486666666666 +x_0=150000.013
+towgs84=-106.8686,52.2978,-103.7329,-0.3366,0.457,-1.8422,-1.2747
+units=m +no_defs
The second one if the official one from the Belgian National Geographic
Institute (http://www.ngi.be/FR/FR4-4.shtm). Both should give
approximately the same results. I have used epsg:31370, which uses the
second definition without errors. The errors in your picture, about 100
meters, look as if no datum transformation has been applied at all.
You could test this by transforming your data points manually with cs2cs
for both towgs84 strings, and compare the results with the position of
the WGS84 coordinates in QGIS
Jan
On 20-1-2010 10:18, Thibaut Gheysen wrote:
> Hi,
> I have a problem in QGIS 1.4.0 when I reproject a gpx file into
> Belgian lambert 72 coordinate system : the waypoints are not correctly
> placed on the map (see this image :
> http://www.fsagx.ac.be/gf/outilslogiciels/Garbel/proj4.jpg). I already
> have a similar problem when writing a GPS software
> (http://lists.maptools.org/pipermail/proj/2006-August/002447.html). To
> solve this I have used this towgs84 parameters :
> +towgs84=-99.059,53.322,-112.486,0.419,-0.83,1.885,-0.999999. In QGIS,
> the towgs84 parameters are different
> (+towgs84=106.869,-52.2978,103.724,-0.33657,0.456955,-1.84218,1). When
> I use my GPS software to reproject into Belgian Lambert 72 the
> waypoints are correctly placed (red points in the image) but not when
> I use QGIS (yellow points). I think thus there is a problem in the
> epsg 31370 definition.
> Best regards,
> Thibaut.
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20100120/65884f3a/attachment.html>
