[Proj] Belge 1972 / Belgian Lambert 72 (31370) - towgs84parameters
Jan Hartmann
j.l.h.hartmann at uva.nl
Thu Jan 21 14:51:28 PST 2010
On 21-Jan-10 12:52, Mikael Rittri wrote:
> Jan Hartmann wrote:
> > No, if QGIS uses PROJ, this is just an error.
> Okay, you may be right that QGIS does not use the file gcs.override.csv.
> But I see that the nad/epsg file of PROJ.4 contains the same erroneous
> +towgs84 parameters for Belge 1972 as the gcs.override.csv.
> (At least PROJ version 4.6.1).
I have been quoting from PROJ 4.7. The older towgs parameter is not
exactly erroneous, it's just a bit les exact
> > PROJ and EPSG use opposite rotational formulas, and PROJ uses
> degrees, EPSG radians.
> I don't agree in the general case. PROJ uses the Position Vector
> Transform, while EPSG is neutral on the rotation sign convention:
> they use the same sign convention as the original source.
> And PROJ uses arc seconds for rotations, while EPSG is neutral
> on the angle unit: they use the same angle unit as the original source
> (usually arc seconds, but sometimes microradians or radians).
> For the EPSG transforms you quote, EPSG use arc-seconds
> for the rotations, but either the Position Vector Transform or the
> Coordinate Frame Rotation depending on whether they got the
> transform from Eurogeographics or directly from Belgium.
My information was for the Dutch and Belgian cases, as from the official
documents. I don't know on what principles EPSG operates, I guess they
just take it as they get it. It is not an easy-to-use database.
Jan
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20100121/dea49a93/attachment.html>
More information about the Proj
