[Proj] Belge 1972 / Belgian Lambert 72 (31370) - towgs84parameters
Jan Hartmann
j.l.h.hartmann at uva.nl
Fri Jan 22 06:27:15 PST 2010
It really looks like a QGIS problem. Perhaps you should send a
bug-report to QGIS, that the correct +towgs84 parameter is the one which
displays your points correctly. If possible, add both images to it.
Jan
On 22-1-2010 13:34, Thibaut Gheysen wrote:
> Hi Jan,
> When I replace towgs84 parameters in QGIS by
> '+towgs84=-99.059,53.322,-112.486,0.419,-0.83,1.885,-0.999999' the
> points are correctly placed (red points in the image). When I remove
> towgs84 parameters, I have a error similar to this with original QGIS
> parameters but the points are not placed at same place
> (http://www.fsagx.ac.be/gf/outilslogiciels/Garbel/proj4-2.jpg). I have
> thus supposed that error come from towgs84 parameters but I'm not a
> proj.4 specialist at all.
> Thibaut.
> 2010/1/22 Jan Hartmann <j.l.h.hartmann at uva.nl
> <mailto:j.l.h.hartmann at uva.nl>>
> Hi Thibaut, your problem doesn't have anything to do with the two
> different Belgian parameters; the error in your picture is too
> big. It looks as if the WGS84 datum shift has not been applied at
> all. You could test this by projecting the points from the Belgian
> Lambert projection to Google without any towgs parameter.
> Jan
> On 22-1-2010 9:37, Thibaut Gheysen wrote:
>> Thanks Jan and Mikael for your responses.
>> As suggested, I have forwarded this bug to the QGIS developer
>> mailing list.
>> Thibaut.
>> 2010/1/21 Jan Hartmann <j.l.h.hartmann at uva.nl
>> On 21-Jan-10 12:52, Mikael Rittri wrote:
>>> Jan Hartmann wrote:
>>> > No, if QGIS uses PROJ, this is just an error.
>>> Okay, you may be right that QGIS does not use the file
>>> gcs.override.csv.
>>> But I see that the nad/epsg file of PROJ.4 contains the same
>>> erroneous
>>> +towgs84 parameters for Belge 1972 as the gcs.override.csv.
>>> (At least PROJ version 4.6.1).
>> I have been quoting from PROJ 4.7. The older towgs parameter
>> is not exactly erroneous, it's just a bit les exact
>>> > PROJ and EPSG use opposite rotational formulas, and PROJ
>>> uses degrees, EPSG radians.
>>> I don't agree in the general case. PROJ uses the Position
>>> Vector
>>> Transform, while EPSG is neutral on the rotation sign
>>> convention:
>>> they use the same sign convention as the original source.
>>> And PROJ uses arc seconds for rotations, while EPSG is neutral
>>> on the angle unit: they use the same angle unit as the
>>> original source
>>> (usually arc seconds, but sometimes microradians or radians).
>>> For the EPSG transforms you quote, EPSG use arc-seconds
>>> for the rotations, but either the Position Vector Transform
>>> or the
>>> Coordinate Frame Rotation depending on whether they got the
>>> transform from Eurogeographics or directly from Belgium.
>> My information was for the Dutch and Belgian cases, as from
>> the official documents. I don't know on what principles EPSG
>> operates, I guess they just take it as they get it. It is not
>> an easy-to-use database.
>> Jan
>> Proj mailing list
>> Proj at lists.maptools.org <mailto:Proj at lists.maptools.org>
>> http://lists.maptools.org/mailman/listinfo/proj
>> Proj mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20100122/af9c4fe7/attachment.html>
More information about the Proj
