[Proj] please help transform of coords for Prishtina DXF
jamesmikedupont at googlemail.com
Sun Jan 24 04:12:24 PST 2010
I have here a dxf file of Prishtina in high quality.
http://www.archive.org/details/PrishtinaStreets
I have been able to convert it to lat/lon like this
cs2cs +proj=utm +zone=34T +ellps=WGS84 +datum=WGS84 +units=m -f \"%.7f\"
Problem is that most of the points are in relative position, there is a grid.
I have pushed a version of two nickels that can process alot of this :
To git at github.com:h4ck3rm1k3/TwoNickels.git
c8e4009..41f23f1 master -> master
It produces osm files with data in three groups :
1. points that are exact on the mark, (few)
2. points on the equator (0,0) relative to something
3. points that seem to be shifted over from utm34T
720496.25, 506444.9375 -> 22.987450699423831679, 4.5791053696411907481
I have created averages of good points versus the shifted ones and
came up with these constant shifts:
$n -= 187380;
$e += 4228672;
They are still 15km off of prishtina..
So I would like one of you to please help with the autocad and
transform all coordinates into some single form so I can convert them.
Or please advice on these points.
thanks,
mike
More information about the Proj
