[Proj] TM06 for Portugal
Roger Oberholtzer
roger at opq.se
Mon Jun 7 04:38:24 PDT 2010
On Mon, 2010-06-07 at 10:18 +0100, Jose Gonçalves wrote:
> Roger
> The test data cannot be correct. ETRS89 coincides with WGS84 (or
> better ITRF) in 1989 and the current discplacement is only a few
> decimeters. The lat-long differences between your coordinates are
> 0.080" and 0.122", which correspond to approximately 2.9 m in lat and
> 2.5 m in long, i. e the differences you get in the projected
> coordinates.
> Yout test point belongs to the portuguese geodetic network. The ETRS89
> coordinates are correct, as you can check in:
> http://www.igeo.pt/produtos/geodesia/vg/rgn/ficha.asp?num=873
> (open with Internet Explorer)
> Where did you get the WGS84 coordinates? They must be wrong.
>From Estradas de Portugal. I agree about the ETRS89 being correct
(meaning that given the proj transformation I described, the expected
northing/easting values are derived). I was surprised when they provided
two sets of lat/long values. They explained them by saying that the two
sets of LAT/LONG describe the same physical location, one in WGS84 and
the other in ETRS89. I have to trust that they have not mislabeled the
data. Especially after I asked for a confirmation.
What I am trying to accomplish is transforming WGS84 LAT/LONG from a GPS
receiver to both TM06 and MPG73 northings/eastings. I have started with
TM06. I will not have any ETRS89 lat/long values. The only reason they
might exist would be if proj makes them internally as a step in
converting the source WGS84 lat/longs into the desired TM06
northing/eastings.
How would you convert WGS84 lat/long into TM06 northing/easting? I know
that WGS84 is so close to ETR89 here that one 'could' use the WGS84
values in the transform from ETRS89 to TM06. But how would I do it the
'proper' way with proj?
> Regards
> José A. Gonçalves
> Univ. of Porto, Portugal
> 2010/6/7 Roger Oberholtzer <roger at opq.se>
> On Thu, 2010-02-18 at 16:40 +0100, Roger Oberholtzer wrote:
> I now have some test data for the conversion from WGS84
> lat/long to TM06
> northing/eastings. The suggested proj conversion of:
> "+proj=tmerc "
> "+ellps=GRS80 "
> "+k=1.0 "
> "+x_0=0 "
> "+y_0=0 "
> "+lon_0=-8.133108333333334 "
> "+lat_0=39.66825833333333 "
> "+towgs84=0,0,0,0,0,0,0 "
> seems in fact to work with ETRS89 lat/long, not WGS84
> lat/long. When
> provided with WGS84 lat/long, the resulting northings/eastings
> are a few
> meters away. (Assuming my test data from the Portuguese Road
> Department
> is correct. I have double checked, so it might very well be.)
> In fact,
> it is a small error, but I want to provide the best I can. I
> am guessing
> that I need to change my +towgs84= to cause the WGS84
> lat/longs to be
> converted to ETRS89. Does anyone know the proper values?
> This begs the question: what does
> http://spatialreference.org/ref/epsg/3763/ assume is the datum
> of the
> original lat/longs? Seems it assumes ETRS89, not WGS84.
> Here is a sample location that I have been provided (all
> altitudes set
> to 0.0):
> Ref (WGS84): Latitude: 41.6743830556 Longitude:
> -8.3312663889
> Ref (ETRS98): Latitude: 41.6744052222 Longitude:
> -8.3312324722
> Ref (TM06): Easting: -16498.151 Northing:
> 222796.720
> The proj conversion above properly converts the ETRS98
> locations to
> TM06. But I want to convert the WGS84 locations to TM06. When
> I try
> that, I get:
> Easting: -16500.981 Northing: 222794.265
> which is 3.747 meters away.
> Roger Oberholtzer
> OPQ Systems / Ramböll RST
> Ramböll Sverige AB
> Krukmakargatan 21
> P.O. Box 17009
> SE-104 62 Stockholm, Sweden
> Office: Int +46 10-615 60 20
> Mobile: Int +46 70-815 1696
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
> Proj mailing list
Roger Oberholtzer
Ramböll Sverige AB
Krukmakargatan 21
P.O. Box 17009
More information about the Proj
