[Proj] Deepwater Horizon. Where is the bottom of the well?
Michael P Finn
mfinn at usgs.gov
Sat Jun 19 17:18:25 PDT 2010
Thanks. Very interesting.
"Clifford J Mugnier" <cjmce at lsu.edu>
To:
"PROJ.4 and general Projections Discussions" <proj at lists.maptools.org>
Date:
06/14/2010 01:05 PM
Subject:
Re: [Proj] Deepwater Horizon. Where is the bottom of the well?
Sent by:
proj-bounces at lists.maptools.org
Inertial systems and their accuracies degrade as a function of time, so
it's pretty easy to calculate the expected error envelope in all three
components. Numerous ZUPTs (Zero velocity Update PoinTs) can help. The
fiber optic ring lasers with absolutely zero moving parts, although more
expensive, are the best alternative to the ring laser gyros that indeed
have one moving part.
I do not know if IXsea has any downhole applications yet, though ...
I used to sell UTM/State Plane transformation software that would run on
an HP-41 calculator to Directional Drilling companies in the Gulf of
Mexico about 25 years ago. They were quite concerned with correcting for
magnetic declination and Grid System convergence angles back then before
small inertial strapdown packages were available for non-DoD applications.
Clifford J. Mugnier, C.P., C.M.S.
Chief of Geodesy,
Center for GeoInformatics
Department of Civil Engineering
Patrick F. Taylor Hall 3223A
LOUISIANA STATE UNIVERSITY
Baton Rouge, LA 70803
Voice and Facsimile: (225) 578-8536 [Academic]
Voice and Facsimile: (225) 578-4578 [Research]
Cell: (225) 238-8975 [Academic & Research]
Honorary Life Member of the
Louisiana Society of Professional Surveyors
Fellow Emeritus of the ASPRS
Member of the Americas Petroleum Survey Group
From: proj-bounces at lists.maptools.org on behalf of Karney, Charles
Sent: Mon 14-Jun-10 13:08
To: PROJ.4 and general Projections Discussions
Subject: [Proj] Deepwater Horizon. Where is the bottom of the well?
Here are some questions related to the Deepwater Horizon accident and
the drilling of relief wells for the readers of this list in the oil
industry.
(1) What is the method of determining the position of an instrument 3km
down a well? Is it seismic, dead reckoning, or what?
(2) What is the typical absolute accuracy of the measured position,
horizontally and vertically (and, if possible, specifically with
reference to the leaking well)? What is the *relative* accuracy?
(I.e., I can imagine that the absolute accuracy is poor because of the
unknown properties of the intervening rock. However, it might be
possible to "find" the same position when drilling the relief well if
the same method is used.)
(3) Is the drill bit instrumented to return the position? How? Or does
a separate logging package need to be inserted into the well? At what
frequency would this be done?
I can piece together some of the answers from wikipedia. However, maybe
I can get more autoritative and more specific answers from this list.
--Charles
Charles Karney <ckarney at sarnoff.com>
Sarnoff Corporation, Princeton, NJ 08543-5300
Tel: +1 609 734 2312
Fax: +1 609 734 2662
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
Proj mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20100619/1a0e640c/attachment.html>
More information about the Proj
