[Proj] Fwd: proj4 definition for European Forest Map
Jose Gonçalves
jagoncal at gmail.com
Thu Jun 24 04:12:32 PDT 2010
Hello
The third definition is ok. Since you are specifying both semi-axis the
flattening is redundant. The first is wrong because +rf should be infinite
in the case of the sphere. Within PROJ syntax you could also use:
proj +proj=laea +lat_0=48 +lon_0=9 +x_0=0 +y_0=0 +R=6378388 +units=m
+no_defs
Regards
José A. Gonçalves
2010/6/24 Agustin Lobo <alobolistas at gmail.com>
> Hi!
> The European Forest Map has the following projection (according to a
> file distributed along with the file):
> Projection: Lambert_Azimuthal_Equal_Area
> Parameters:
> False_Easting: 0.000000
> False_Northing: 0.000000
> Central_Meridian: 9.000000
> Latitude_Of_Origin: 48.000000
> Linear Unit: Meter (1.000000)
> Coordinate system
> Geographic Coordinate System:
> Angular Unit: Degree (0.017453292519943299)
> Prime Meridian: Greenwich (0.000000000000000000)
> Datum: D_User_Defined
> Spheroid: User_Defined_Spheroid
> Semimajor Axis: 6378388.000000000000000000
> Semiminor Axis: 6378388.000000000000000000
> Inverse Flattening: 0.000000000000000000
> I've made several trials to set up a custom projection (in QGIS):
> 1.
> +proj=laea +lat_0=48 +lon_0=9 +x_0=0.000 +y_0=0.000 +a=6378388.0000
> +b=6378388.000 +rf=0.000 +units=m +no_defs
> Rejected by the custom projection tool as erroneous
> 2.
> +b=6378388.000 +f=0.000 +units=m +no_defs
> Accepted by the custom projection tool but the Properties dialog does
> not accept it
> 3.
> +b=6378388.000 +units=m +no_defs
> Seems to work fine.
> I'd like if someone could actually confirm that the third proj4
> definition is actually
> in accordance with the definition provided in the server and that I
> have reproduced at the beginning of this
> message. I'm not sure if option 1 and 2 are rejected because they are wrong
> or
> this is a QGIS problem (message sent to the QGIS list remains unanswered).
> I also would like answer if there is a document instructing how to
> translate PROJCS specifications
> into proj4 format.
> Thanks!
> Agus
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20100624/700c11d9/attachment.html>
More information about the Proj
