[Proj] Portuguese Modified Grid - Datum 73
Jose Gonçalves
jagoncal at gmail.com
Thu Jun 24 17:36:52 PDT 2010
2010/6/23 Roger Oberholtzer <roger at opq.se>
> On Wed, 2010-06-23 at 15:11 +0200, Jean-Claude REPETTO wrote:
> > +towgs84=-239.749,88.181,30.488,0.263,0.082,1.211,2.229
Those +towgs84 parameters convert Datum73 to WGS84 with errors of the order
of 1 meter. I have a datum shift grid file to convert from Datum 73 to
ETRS89 available on the address:
http://www.fc.up.pt/pessoas/jagoncal/coordenadas/pt73_e89.gsb
You can convert ETRS89 long-lat to projected Datum73 with the follwoing
command line (errors in general smaller than 10 cm) :
cs2cs +init=epsg:4258 +towgs84=0,0,0 +to +init=epsg:27492
+nadgrids=pt73_e89.gsb
The WGS84 coordinates of your test point are not very accurate.
Regards
José A. Gonçalves
University of Porto, Portugal
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20100625/75fd6e15/attachment.html>
More information about the Proj
