[Proj] +axis switch to control axis orientation
Frank Warmerdam
warmerdam at pobox.com
Mon Mar 1 10:42:15 PST 2010
support.mn at elisanet.fi wrote:
> Hello,
> my opinion is that it is an improvement and since it is downwards compatible
> it is also very welcome. My only concern is that it only works partially? An user
> might expect it to do the hole work but it just did half of it? How could it be
> implemented so that all routines used that switch?
Janne,
I presume your concern is that it has no effect on the pj_inv() and pj_fwd()
functions. It is possible to implement support for it within them rather than,
or in addition to in pj_transform() but it would be more complicated for a
few reasons and likely slower since the axis switching decision would need
to be checked for every point rather than once for a whole array of points to
be transformed.
There are already a bunch of services that only apply for applications
going through pj_transform(). These include prime meridian handling
(+pm), datum shifting and alternate longitude wrapping (ie. 0 to 360
instead of -180 to 180). So I think there is at least a precident for
the operation of the two API entry points being fairly distinct.
In part, I'm trying to keep the functioning of pj_fwd() and pj_inv() as
focused on the projection function as possible, while treating
pj_transform() as a higher level "coordinate system transformations"
function. One benefit of this is that in theory at some point I could
replace everything from pj_fwd()/pj_inv() down with use of Gerald's new
library while treating pj_transform() and all it's services as a higher
level function that would remain distinct from the low level projections
library.
What do you think? Is my reasoning at all convincing?
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
More information about the Proj
