[Proj] Region Finder
Frank Warmerdam
warmerdam at pobox.com
Thu Mar 11 15:51:58 PST 2010
` ` wrote:
> I have a the latitude/longitudes for a school boundary and I want to
> know if an address is in that boundary. Is there a way to find out if a
> coordinate is within a latitude/longitude boundary? Or even better
> would be to use an address and find out what boundary it is in.
Daniel,
There are two parts to your question, neither of which have to do with
PROJ.4:
1) The ability to determine the lat/long location associated with an
address (ie. a postal address). This is called geocoding. The following
posts by Martin Davis should provide a bit of background on geocoders.
http://lin-ear-th-inking.blogspot.com/2010/03/open-source-geocoders.html
http://lin-ear-th-inking.blogspot.com/2010/03/more-open-source-geocoders.html
2) The ability to determine if a point is within a polygon or conversely
which polygon within a set the point is in. This is a geometry operation.
One of the best known geometry libraries is GEOS (a C++ port of JTS which
oddly is also Martin Davis' project).
http://geos.osgeo.org/
Good luck,
and watch the world go round - Rush | Geospatial Programmer for Rent
More information about the Proj
