[Proj] List of supported projections and ellipsoids
Frank Warmerdam
warmerdam at pobox.com
Mon Mar 15 03:57:42 PDT 2010
LOTT Jean-Baptiste wrote:
> Hi all,
> I would need to get the list of projections and ellipsoids that I can
> use with the library. What I am looking for is a list like the one that
> is returned when calling cs2cs -lp and cs2cs -le. Those functions use
> pj_get_list_ref and pj_get_ellps_ref to get those lists, is there any
> way to do the same thing using the API?
Jean-Baptiste,
I see that those functions and the structure defines they are based on
are not currently part of the public api in proj_api.h. However, they
are available if you include the internal projects.h include file. I
generally discourage this, but it may still be the expedient thing for
you to do.
I might make sense to move these structure definitions and function
prototypes to proj_api.h if we want to consider them generally available.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
More information about the Proj
