[Proj] Fw: failure notice
Hamish
hamish_b at yahoo.com
Fri Mar 26 17:10:09 PDT 2010
try, try again.
--- MAILER-DAEMON at n1.bullet.mail.gq1.yahoo.com <MAILER-DAEMON at n1.bullet.mail.gq1.yahoo.com> wrote:
> <proj at lists.maptools.org>:
> No MX or A records for lists.maptools.org
> --- Below this line is a copy of the message.
> Hamish wrote:
> > or you probably could have installed the "proj-data" package;
> > the main package is currently missing that as a dependency.
> > To be fixed in the upstream DebianGIS sources..
> > http://packages.ubuntu.com/karmic/i386/proj-data/filelist
> actually, no.
> In Karmic proj depends of libproj0 which depends on
> proj-data.
> so if proj-data somehow manages not to be installed I'm not
> sure what the problem is/was.
> Hamish
More information about the Proj
