[Proj] Coordinate within an area ?
Roger Oberholtzer roger at opq.se
Tue Mar 30 05:05:13 PDT 2010
On Tue, 2010-03-30 at 04:18 -0700, Hamish wrote:
> Martin Raspaud wrote:
> > Is there a way to know if a point defined by its lon/lat
> > coordinates is within
> > an area which corners are given in lon/lats also ?
> yes, there are many methods to do this. try a web search
> for "point in polygon". if it is corners of a box, it's trivial..
As lat/longs and not meters? On a non-flat surface? Isn't it more
complicated with lat/long for this? I would think you should convert the
values to northings/eastings and do the test on that data. Then it could
perhaps be a bounding box test.
My next questions would be: (1) how accurate does it need to be? and (2)
If it is done everywhere in the world, what projection to use to reduce
error? I would think SMHI would be working in and near Sweden, and would
be ok with SWEREF99.
Roger Oberholtzer
OPQ Systems / Ramböll RST
Ramböll Sverige AB
Krukmakargatan 21
P.O. Box 17009
SE-104 62 Stockholm, Sweden
Office: Int +46 10-615 60 20
Mobile: Int +46 70-815 1696
