[Proj] NAD 27 v 83 Distances
strebe at aol.com
strebe at aol.com
Fri Oct 1 13:53:37 PDT 2010
Does that follow? Aren’t the local datums, with ellipsoids fitted to the local surface, generally more accurate than a single ellipsoid for the entire earth? I’ve certainly found that vertical coordinates are generally worse on WGS84.
Granted, NAD27 covers a vast region, so perhaps it deviates further from reality than some of the more local datums in use around the world. But without a study computing deviations from the geoid on both, it seems a bit breezy to just claim the newer one is “better” given that its purpose is the best global system rather than the best local system. That fact that NAD83 is the “current legal datum” seems irrelevant to the question of accuracy of real distances.
Obviously not important in the context of the original posting; either surface is a fiction and real distances over real terrain will deviate from either datum far more than distances on the two datums will deviate from each other.
Regards,
— daan Strebe
-----Original Message-----
To: PROJ.4 and general Projections Discussions <proj at lists.maptools.org>
Sent: Fri, Oct 1, 2010 12:42 pm
Subject: Re: [Proj] NAD 27 v 83 Distances
Because it is the current legal datum of the United States, and it is based in part on artificial satellite observations. The semi-major axis of the GRS80 ellipsoid has been proven to be correct within a few centimeters based on decades of observing GPS orbits.
NAD27 is referenced to an ellipsoid computed by hand and published by COL Alexander Ross Clark, R.E. in 1866.
Since this is a discussion of distances, NAD83 is closest to the truth as a matter of scale and shape.
Best regards,
Clifford J. Mugnier, C.P., C.M.S.
Chief of Geodesy,
Center for GeoInformatics
Department of Civil Engineering
Patrick F. Taylor Hall 3223A
LOUISIANA STATE UNIVERSITY
Baton Rouge, LA 70803
Voice and Facsimile: (225) 578-8536 [Academic]
Voice and Facsimile: (225) 578-4578 [Research]
Cell: (225) 238-8975 [Academic & Research]
Honorary Life Member of the
Louisiana Society of Professional Surveyors
Fellow Emeritus of the ASPRS
Member of the Americas Petroleum Survey Group
From: proj-bounces at lists.maptools.org on behalf of strebe at aol.com
Sent: Fri 01-Oct-10 14:26
To: proj at lists.maptools.org
>The difference of distances should be modest between the two datums, with of
>course the NAD83 distances being the better of the two.
Why would NAD83 be the better of the two?
Regards,
— daan Strebe
Sent: Fri, Oct 1, 2010 9:28 am
Robert McFaul wrote:
> Hi,
> I'm concerned about whether ground surface distances are different between
> NAD27 and NAD83. I'm in California (southern) and thinking about a
> conversion
> of a project to NAD83. I have some cross section distances measured (1000 to
> 3000 feet in length) and suddenly am wondering what sort of differences
> might
> be involved by this change in systems.
Robert,
course the NAD83 distances being the better of the two. I did a test for a
random point in southern california and the change is datum shift deltas over
one kilometer was about 1cm. You can do similar tests for any area of interest:
cs2cs -f '%.4f' +proj=utm +zone=11 +datum=NAD27 +to +proj=utm +zone=11
+datum=NAD83
440000 3750000
439919.4833 3750196.3019 0.0000
440000 3751000
439919.4784 3751196.3100 0.0000
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
Proj mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20101001/a423e83b/attachment.html>
More information about the Proj
