[Proj] 4.7.1 bug report
Frank Warmerdam
warmerdam at pobox.com
Sun Oct 3 09:22:06 PDT 2010
Markus Neteler wrote:
> On Sun, Oct 3, 2010 at 5:24 PM, <support.mn at elisanet.fi> wrote:
>> Hello,
>> I just switched back to version 4.6.0 (21 Dec 2007) which
>> seems to work correctly. I was testing version 4.7.1 but
>> it started to produce random (!!??) datums shift errors.
>> Randomly datum shift returns HUGE_VAL without any
>> reason for release version - debug version seems to
>> work better. I did not check any more but switched back
>> to 4.6.0 which seems to work well all the time.
>> Reason is so far unknown.
> In case that 4.7.1 corresponds to trunk, I can report that it
> is broken for GRASS GIS (4.7.0 works). The problem seems
> to be the change
> "roll projCtx through various other low level functions"
> Consider to try 4.7.0 which is the latest published version.
> Maybe trunk is yet in transition.
Markus / Janne,
I am not aware of trunk being broken. A bug report with something I can
reproduce and fix would be quite helpful.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
More information about the Proj
