[Proj] Stereo 1970 (EPSG 31700)
Thibaut Gheysen gheysen.t at gmail.com
Mon Oct 4 07:14:36 PDT 2010
I have a problem in QGIS with the Stereo 1970 coordinate system (EPSG
31700).
I have a shapefile in the WGS 84 coordinate system (from a GPS device). I
projected this shapefile in Stereo 1970 using ArcMap.
In ArcMap, the source and projected points are in the same place. In Qgis, I
have a deviation of about 100 meters when displaying this 2 shapefiles and
activating the "on the fly projection" (stereo.jpg). This deviation is the
same that the one I obtain in ArcMap without "geographic coordinate system
transformations".
Someone has an idea to solve this problem ?
Thanks in advance,
Thibaut.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20101004/97eddc90/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20101004/97eddc90/attachment.jpg>
