[Proj] Area of a spherical polygon
Noel Zinn (cc) ndzinn at comcast.net
Tue Sep 21 14:20:18 PDT 2010
pi / 2pi, what you really want is tau.  Follow these links!
http://www.math.utah.edu/~palais/pi.pdf
http://tauday.com/
Noel
Noel Zinn, Principal, Hydrometronics LLC
+1-832-539-1472 (office), +1-281-221-0051 (cell)
noel.zinn at hydrometronics.com (email)
http://www.hydrometronics.com (website)
Sent: Tuesday, September 21, 2010 3:45 PM
To: "Mikael Rittri" <Mikael.Rittri at carmenta.com>; "PROJ.4 and general
ProjectionsDiscussions" <proj at lists.maptools.org>
Subject: Re: [Proj] Area of a spherical polygon
>> From: Mikael Rittri [Mikael.Rittri at carmenta.com]
>> Sent: Tuesday, September 21, 2010 05:06
>> Hello Charles,
>> you wrote:
>> > * the formula for A applies only if the polygon does not include a pole
>> >   (if it does, then add +/- pi to the result);
>> Don't you mean +/- 2pi ?
> Yup.  Sorry about that.
>> > * I would be interested to know if this formula for S12 is already
>> >   known.
>> There is an article
>> Robert D. Miller, Computing the area of a spherical polygon, Graphic
>> Gems IV, chapter II.4, pages 132 - 137.  It is on books.google.com,
>> but without pages 135 and 136:
>> Your formula for S12 does not appear (in any obvious form), but
>> Miller's method reminds me a little of yours. Instead of summing the
>> areas between each segment and the equator, Miller sums the areas
>> between each segment and a pole.  I don't know how well-conditioned
>> his method is for small polygons.
> Thanks for the pointer.  I have located the code that implements this
> algorithm at
> http://people.sc.fsu.edu/~jburkardt/cpp_src/geometry/geometry.html
> routine, sphere_polygon_area_3d, in geometry.C.  This uses L'Huilier's
> theorem
> http://books.google.com/books?id=3uBHAAAAIAAJ&pg=PA70
> for the area of a spherical triangle in terms of its three sides.  If
> the edge is specified by the latitudes and longitudes of its endpoints,
> then this entails computing the length of the edge and substituting the
> result in a somewhat elaborate formula.
> In contrast, I started with the formula for the area of a spherical
> triangle in terms of two sides and the included angle (on p 71 of
> Todhunter).  If one vertex is the pole then the sides are the two
> co-latitudes, the included angle is the longitude difference, and the
> formula can be used directly without the need to calculate an
> intermediate result.  My (meager) contribution is to recast the formula
> to give the area between the edge and the equator.
> My expectation is that this will yield more accurate results than
> Miller's method.  I will benchmark both approaches to confirm or refute
> this.
> By the way, Miller's paper contains one geographic howler: In the
> section "Geographic Particulars" he says that ellipsoidal effects can be
> included for small polygons by taking the effective radius to be
>    r(phi) = a/sqrt(1 - e^2 * sin(phi)^2)
> Surely, this should be
>    r(phi) = b/(1 - e^2 * sin(phi)^2)
> Charles Karney <ckarney at sarnoff.com>
> Sarnoff Corporation, Princeton, NJ 08543-5300
> Tel: +1 609 734 2312
> Fax: +1 609 734 2662
> This message (and any attachments) contains Sarnoff proprietary
> information. Such information may be subject to the terms of
> confidentiality or other agreements. If you are not the named addressee,
> you should not disseminate, distribute, or copy this email. If you have
> received this email by mistake, please notify the sender immediately by
> email and delete this email from your system. If you are not the intended
> recipient, you are notified that disclosing, copying, distributing, or
> taking any action in reliance on the contents of this information is
> strictly prohibited.
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
