[Proj] Dutch correction grid
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Thu Apr 7 02:03:18 PDT 2011
Hi Jan,
great! Thanks in advance.
I got the spreadsheet from:
http://www.rdnap.nl/kenniscentrum/databestanden/normaal_amsterdams_peil/documenten/index.aspx
Best regards,
Bart
> If someone could give me some pointers to the grid shift format and the
> way it is used in PROJ, I will have a go at producing a grid shift file
> from this spreadsheet. Where did you get it from, Bart?
> Jan
> On 7-4-2011 9:18, Bart van den Eijnden (OSGIS) wrote:
>> Hi,
>> did anybody ever attempt to transform the information from the Dutch
>> correction grid into a format for a datum shift grid file that PROJ.4
>> can
>> read?
>> http://www.rdnap.nl/images/Landelijk%20correctiegrid%20nieuwe%20NAP-publicatie_tcm174-280038.xls
>> Best regards,
>> Bart
>> Proj mailing list
>> Proj at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/proj
More information about the Proj
