[Proj] Dutch correction grid
Schmitz, Uwe uwe.schmitz at bezreg-koeln.nrw.de
Mon Apr 11 00:49:41 PDT 2011
Jan,
I don't know if it was already mentioned, but there is a
program called GDAy from an Australian governmental
authority. It can be downloaded for Windows from
here:
http://www.derm.qld.gov.au/property/surveying/files/gday21iex.exe
The parent page with docuemntation is here:
http://www.derm.qld.gov.au/property/surveying/gdasoftware.html
Beside transforming coordinates it is able to convert
NTv2-ASCII to NTv2-Binary. So if you can produce an ASCII
file of your data, conforming to the description, you
can use the prog to convert it to binary.
This feature is a little bit hidden:
Load the grid file with menu point:
File/Distortion Grid Settings/Select New Grid File...
(attention: the extension has to be ".asc"!)
After that save the grid with menu point:
File/Distortion Grid Settings/Export Grid File/...to Binary
That's it.
good luck
uwe
