[Proj] Google Mercator Projection
zagot
maurelio at live.it
Thu Aug 4 04:22:42 PDT 2011
i have copied from the official note definition
cs2cs +proj=latlong +datum=WGS84 \
+to +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 \
+x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs
ok.. however with the datum now the result is different:-626172.1357121646,
6853979.3008168638
but if I transform this point using CS2CS tool, as follows:
echo -5.625 52.4827802220782 | cs2cs -f â%.10fâ +init=epsg:4326 +to
+init=epsg:3857
then I'll get the following result instead:
(-626172.1357121646, 6887893.4928337997)
why this difference? what's is correct?
thanks
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Google-Mercator-Projection-tp6651663p6652311.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
More information about the Proj
