[Proj] Google Mercator Projection
zagot
maurelio at live.it
Thu Aug 4 08:59:14 PDT 2011
Hi Josè,
you are right I'm confusing by official note...
1)adding +nadgrids=@null is not necessary and the first result is correct
6887893.4928337997
3) adding datum is wrong
finally the follow code is simply correct and my maps is center fine with
proj.dll 4.4.6 :)
from ..."+proj=latlong +datum=WGS84";
to... "+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0
+y_0=0 +k=1.0 +units=m +no_defs"
thanks to all
g.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Google-Mercator-Projection-tp6651663p6653287.html
Sent from the PROJ.4 mailing list archive at Nabble.com.
More information about the Proj
