[Proj] setting lambert conformal conic projection in gdalwarp
Jose Gonçalves
jagoncal at gmail.com
Tue Aug 16 15:28:20 PDT 2011
Matt
There is a problem with the lcc projection. The two latitudes +lat_1 and
+lat_2 define the standard parallels, where the cone intersects the
ellipsoid. They can't be both zero (the cone would degenerate into a
cylinder).
There are two more possible problems.
In the source coordinate system there is no ellipsoid definition. It seems
that gdalwarp is assuming to be WGS84.
In the output system you have UTM in uppercase. The proj standard is
lowercase.
Regards
José
2011/8/16 Mathew Fox <mathewfoxx at gmail.com>
> Hi all,
> I am having problems with the Lambert Conformal Conic projection.
> I am trying to convert an LCC file into UTM:
> gdalwarp -of GTiff -s_srs '+proj=lcc +lat_1=0 +lat_2=0 +lat_0=50 +lon_0=0
> +x_0=0 +y_0=0 +units=m +no_defs' -t_srs '+proj=UTM +zone=18 +units=m
> +datum=NAD83 +no_defs' cols.asc cols.tif
> I got the parameters from an existing LCC file.
> Problem is, when I try to set this projection to my file I get an error
> about the projection parameters.
> ERROR 6: Failed to initialize PROJ.4 with `+proj=lcc +lat_1=0 +lat_2=0
> +lat_0=50 +lon_0=0 +x_0=0 +y_0=0 +ellps=WGS84 +units=m +no_defs '.
> conic lat_1 = -lat_2
> Thank you in advance for any suggestions.
> Matt.
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20110816/a277150d/attachment.html>
More information about the Proj
