[Proj] ITRF to GDA94 transformation problems - bug in 7 parameters?
Mikhail Tchernychev
misha at mail.geometrics.com
Thu Aug 25 14:02:20 PDT 2011
Hello everyone,
I am trying to re-produce transformation described in this document:
http://www.ga.gov.au/image_cache/GA3795.pdf
appendix B, and I am getting errors about 0.11 m
My
+towgs84=-0.054100,-0.019100,0.009600,0.010833,0.010703,0.011403,0.006859,
the same
numbers as in the article.
This is what I get if I use lat / lon -> lat/lon
cs2cs +from -w4 +proj=latlong +datum=WGS84 +to
+towgs84=-0.054100,-0.019100,0.009600,0.010833,0.010703,0.011403,0.006859 +proj=latlong
<<EOF
133d53'7.8574"E 23d40'12.4314"S 603.287
EOF
Computed and Correct results:
133d53'7.8454"E 23d40'12.4468"S 603.261
133d53'7.8478"E 23d40'12.4461"S 603.350
I also tried to convert directly geocentric coordinates listed in the
article. This is what I got:
cs2cs -f "%.3lf" +from -w4 +proj=geocent +datum=WGS84 +to
+proj=geocent <<EOF
-4052052.048 4212836.105 -2545105.587
EOF
computed and correct result
-4052051.655 4212836.186 -2545106.011
-4052051.765 4212836.205 -2545106.027
I attached script with cs2cs calls, which exhibits the problem.
Help is greatly appreciated,
Thank you
Mikhail
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20110825/d5853800/attachment.ksh>
More information about the Proj
