[Proj] New proposal of JNI bindings for Proj.4
Frank Warmerdam
warmerdam at pobox.com
Thu Aug 25 15:08:44 PDT 2011
On Thu, Aug 25, 2011 at 2:59 PM, Martin Desruisseaux
<martin.desruisseaux at geomatys.fr> wrote:
> Do peoples agree to commit those new JNI bindings (without GeoAPI
> dependency) straight into the Proj.4 SVN code base, together with the
> existing bindings? There will be no change in the existing configuration
> that enable/disable compilation of JNI bindings.
Martin,
I have no objection to your committing the new bindings,
assuming there is no hue and cry from folks using the old
bindings. I assume they are not widely used currently.
It is a pity that compatibility with the existing bindings
could not be easily preserved, but I can live with this.
> What do we do with existing bindings?
I think it does not make sense to have two Java
bindings. I am ok with removing the existing ones
in favor of your changes ones.
Please ensure the Java changes are prominently noted in the
ChangeLog file. I will try to note it in the release announcement.
Best regards,
and watch the world go round - Rush | Geospatial Software Developer
More information about the Proj
