[Proj] New proposal of JNI bindings for Proj.4
    Frank Warmerdam
    warmerdam at pobox.com
    Sat Aug 27 09:41:35 PDT 2011
On 11-08-27 09:22 AM, Martin Desruisseaux wrote:
> I have just done my first commit on
> http://svn.osgeo.org/metacrs/proj/trunk/proj/src/jniproj.c
> On the memory leak issue, I applied only the trivial fix. I documented the
> other issues (without fixing them) for historical records.
> I will wait a little bit before to commit the new JNI bindings in replacement
> to the existing ones, in case I did something wrong with this first commit or
> someone object to the replacement.
Martin,
 From my point of view you should go ahead.  Please also update the
ChangeLog file to mention your fixes to the old bindings and additions
as you apply them.
> On a related note, I attached to this email a patch for minor typos I found by
> accident. Because they in C files outside the JNI bindings, I prefer to not
> touch them without permission.
Applied.  Don't hesitate to make changes elsewhere that are low risk
like this.
Best regards,
More information about the Proj
