[Proj] [proj4] epsg:31370 possible wrong parameters
Willy-Bas Loos
willybas at gmail.com
Thu Feb 17 10:46:56 PST 2011
Hi, we had issues displaying data from epsg:31370
We changed some "-" signs, according to a definition that i found in
postgis, and that solved the issue.
We use Rel. 4.7.1, 23 September 2009.
The parameters that showed us the expected result were:
<31370> +proj=lcc +lat_1=51.16666723333333 +lat_2=49.80333339 +lat_0=90
+lon_0=4.367486666666666 +x_0=150000.013 +y_0=5400088.438 +ellps=intl
+units=m
+towgs84=-106.868628,52.297783,-103.723893,0.336570,-0.456955,1.842183,-1
+no_defs <>
The minus signs and the versions in the several packages in which proj4 is
included is getting me a bit dazzled, so i might be mistaken.
Hope this is constructive.
Cheers,
WBL
"Patriotism is the conviction that your country is superior to all others
because you were born in it." -- George Bernard Shaw
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20110217/db7c65eb/attachment.html>
More information about the Proj
