[Proj] pj_init_plus allocation question
Mikhail Tchernychev misha at mail.geometrics.com
Mon Feb 28 14:29:10 PST 2011
I am sorry, this is my fault. Thank you for explanation.
Best
Mikhail
On 11-02-28 04:26 PM, Mikhail Tchernychev wrote:
> >      Hello List,
> >  It's just appeared to me that pj_allocation_plus does not allocate new
> >  memory each time it is called. Depending on the projection parameters,
> >  it returns already
> >  allocated structure from the previous call.
> >  It means that there should not be matching pj_free call for each
> >  pj_init_plus.
> >  Is it correct?
> >  What is if two +proj=latlong projections with different parameters are
> >  used in the program?
> >  Would proj_init_plus return the same pointer for both of them?
> >  Shall I keep track of all pj_free_calls myself (and possibly reference
> >  count) to clean up?
> >  Unfortunately I could not search proj mail list - it appeared there is
> >  no option to search.
Mikhail,
The proj list would be a better place for this question.
pj_init_plus() will allocate a new PJ object and there should
be a corresponding pj_free() call for each successful call to
pj_init_plus().
I am not sure what lead you to a different conclusion.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com light and sound - activate the windows |
http://pobox.com/~warmerdam and watch the world go round - Rush |
Geospatial Programmer for Rent
_______________________________________________ FWTools mailing list
FWTools at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/fwtools
http://fwtools.maptools.org/
<html>
<body>
<FONT face=  "Arial" size=  "-1">
PLEASE NOTE: This message, including any attachments, may
include privileged, confidential and/or inside information. Any
dissemination, distribution or copy of this communication by
anyone other than the intended recipient is strictly
prohibited. If you are not the intended recipient, please
notify the sender by replying to this message and then delete
it from your system. Information provided via electronic media
is not guaranteed against defects including translation and
transmission errors. The company accepts no liability for any
damage caused by any virus transmitted by this email.
Geometrics Inc.
2190 Fortune Drive
San Jose, CA 95131 USA
</FONT>
</body>
</html>
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20110228/1991b32c/attachment.html>
