[Proj] gdaltransform and cs2cs don't agree ...
Jose Gonçalves
jagoncal at gmail.com
Mon Jan 17 05:36:22 PST 2011
If you add the +wktext control to the strings the result becomes the same:
C:\>gdaltransform -s_srs "+init=IGNF:MILLER +wktext" -t_srs "EPSG:4326
+wktext"
-20037504 10018752
-179.999960988061 72.7828424759274 0
Regards
José A. Gonçalves
2011/1/17 Jean-Claude Repetto <jrepetto at free.fr>
> Hello,
> I have found a case where gdaltransform and cs2cs don't give the same
> results :
> $ gdaltransform -s_srs +init=IGNF:MILLER -t_srs EPSG:4326
> -20037504 10018752
> 179.798600354466 72.943850852954 12400.9953186931
> $ cs2cs -f "%.11f" +init=IGNF:MILLER +to +init=epsg:4326
> -20037504 10018752
> -179.99996098806 72.78284247593 0.00000000000
> Can somebody confirm the bug ? If it is not a bug, is there an explanation
> I am using PROJ-4.7.0 and GDAL-1.8.0.
> Regards,
> Jean-Claude
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20110117/cba9fb09/attachment.html>
More information about the Proj
