[Proj] hammer parameters?
strebe at aol.com
strebe at aol.com
Wed Jan 19 12:03:09 PST 2011
I have been assuming that someone who knows something about proj would speak up. I don’t know anything about proj. However, Snyder’s formulation of Hammer includes a W parameter which controls the amount of bending in the parallels. The standard Hammar uses W = 1/2. Eckert-Greiffendorf uses W=1/4.
Perhaps M is the horizontal compression/vertical exaggeration.
To achieve Briesemeister under these assumptions, you would set W = 1/2, M = 0.93541 (or perhaps its reciprocal), and the projection center to 45°N. So, again, though I know nothing about proj, I assume you will need “ob_tran”, which I infer to mean oblique transformation or somesuch.
— daan Strebe
http://www.mapthematics.com
-----Original Message-----
From: William Kyngesburye <woklist at kyngchaos.com>
To: PROJ.4 and general Projections Discussions <proj at lists.maptools.org>
Sent: Wed, Jan 19, 2011 11:47 am
Subject: Re: [Proj] hammer parameters?
So, can anyone tell me what the M and W parameters mean, or at least what values
to use to get the Breisemeister (without using ob_tran)?
On Jan 13, 2011, at 11:01 AM, William Kyngesburye wrote:
> On Jan 12, 2011, at 5:33 PM, Frank Warmerdam wrote:
>> Folks,
>> For what it is worth, it is possible to embed a literal PROJ.4 string
>> in GDAL/OGR WKT in which case that will be used as the translation to
>> PROJ.4 format.
>> eg.
>> PROJCS["UTM Zone 11, Northern Hemisphere",
>> GEOGCS["WGS 84",
>> DATUM["WGS_1984",
>> SPHEROID["WGS 84",6378137,298.257223563,
>> AUTHORITY["EPSG","7030"]],
>> TOWGS84[0,0,0,0,0,0,0],
>> AUTHORITY["EPSG","6326"]],
>> PRIMEM["Greenwich",0,
>> AUTHORITY["EPSG","8901"]],
>> UNIT["degree",0.0174532925199433,
>> AUTHORITY["EPSG","9108"]],
>> AUTHORITY["EPSG","4326"]],
>> PROJECTION["Transverse_Mercator"],
>> PARAMETER["latitude_of_origin",0],
>> PARAMETER["central_meridian",-117],
>> PARAMETER["scale_factor",0.9996],
>> PARAMETER["false_easting",500000],
>> PARAMETER["false_northing",0],
>> UNIT["Meter",1],
>> EXTENSION["PROJ4","+proj=utm +zone=11 +datum=WGS84 +wktext"]]
>> When passing proj.4 strings to GDAL utilities which take
>> PROJ.4 as input you can include the +wktext option to force
>> literal inclusion of the PROJ.4 string. For projections
>> completely not supported by GDAL you will need to create
>> WKT with some sort of fake projection (perhaps just use
>> the above and update the EXTENSION[] portion.
> I tried this a few months ago for another unsupported projection in GDAL with
no luck. Doesn't work here either. Quote from Evan Rouault:
> "+wktext cannot help when OSR doesn't recognize the projection. It only helps
> to keep the extra options that OSR doesn't handle by itself."
> So, if GDAL doesn't support ob_tran, +wktext won't help.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> First Pogril: Why is life like sticking your head in a bucket filled with
hyena offal?
> Second Pogril: I don't know. Why IS life like sticking your head in a bucket
filled with hyena offal?
> First Pogril: I don't know either. Wretched, isn't it?
> -HitchHiker's Guide to the Galaxy
> Proj mailing list
> Proj at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/proj
All generalizations are dangerous, even this one.
Proj mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20110119/4c8193f6/attachment.html>
More information about the Proj
