[Proj] NGS Control Points
Robert McFaul robert at dgi.com
Tue Jun 21 09:45:12 PDT 2011
Hello,
I have noticed that control points from the National Geodetic Survey (USA)
NAD83 to NAD27 transform values do not agree with transforms done using BM.
I have applied the 1983 to 1927 shift values provided in the data sheets and
compared these to an actual transform run. The transform shows a
difference,
for instance for point HT0774, of a small amount.
    Data sheet (NAD83):   37.77092832 N     -122.39812240
    Data sheet (NAD27):   37.77098056 N     -122.39707500
    Transform 83 to 27:   37.77099882 N     -122.39704051
Are these differences so small that one need not worry? If I calculated this
correctly the difference is around 3.5 feet for the latitude. I'm not a
geodecist and realize that the process is not absolute.
Why the difference?
Thanks.
Robert McFaul
Dynamic Graphics, Inc.
Alameda, CA. USA
