[Proj] Ellipsoidal Orthographic
Clifford J Mugnier cjmce at lsu.edu
Tue Jun 28 11:41:28 PDT 2011
Charles,
Using the closed form for the geocentric inverse is OK for surface mapping, but for a more universal application that will work with aerial photography and particularly with satellite imagery, the closed form deteriorates with altitude above the ellipsoid.  The iterative form will accommodate orbital imagery altitudes with no loss in computational precision.  That's a significant consideration since the "Oil Patch" indeed uses orbital imagery in their exploration activities.
Cliff
Clifford J. Mugnier, C.P., C.M.S.
Chief of Geodesy,
Center for GeoInformatics
Department of Civil Engineering
Patrick F. Taylor Hall 3531
LOUISIANA STATE UNIVERSITY
Baton Rouge, LA  70803
Voice and Facsimile:  (225) 578-8536 [Academic]
Voice and Facsimile:  (225) 578-4578 [Research]
Cell: (225) 328-8975 [Academic & Research]
Honorary Life Member of the
Louisiana Society of Professional Surveyors
Fellow Emeritus of the ASPRS
Member of the Americas Petroleum Survey Group
From: proj-bounces at lists.maptools.org on behalf of Charles Karney
Sent: Tue 28-Jun-11 12:59
To: PROJ.4 and general Projections Discussions
Subject: Re: [Proj] Ellipsoidal Orthographic
Noel,
You use an iterative method to solve for the reverse projection.  But
the reverse projection can be written in closed form.  Recovering the 3d
position [x,y,z] from the easting and northing entails solving a
quadratic equation, so that you get 2 or 0 (or exceptionally 1) root, as
expected.
I can provide you with the outline of the solution if you want.
   --Charles
On 06/28/11 07:43, Noel Zinn (cc) wrote:
> The only equations for the ellipsoidal orthographic that I've ever found
> published (in a book or journal) are those of Bugayevskiy and Snyder (1995),
> which are complicated and (the authors acknowledge) truncated.  Following
> EPSG Guidance Note 7, Part 2, I've prepared a presentation on the
> ellipsoidal orthographic that offers simple, exact equations.  The
> derivation also suggests that the ellipsoidal orthographic is unique among
> projections, being transitional between distorted cartography in 2D and
> undistorted visualization in 3D on a computer in ECEF or ENU (topocentric)
> coordinates.  A link to the presentation follows:
> http://www.hydrometronics.com/downloads/Ellipsoidal%20Orthographic%20Projection.pdf
> Does anyone in this group have other sources of information on the
> ellipsoidal orthographic?
Proj mailing list
Proj at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20110628/4b492a9e/attachment.html>
